주요 콘텐츠로 건너뛰기
Kindle 1st Generation SD Card Reader Replacement
필요한 것
  1. Kindle 1st Generation SD Card Reader Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the grey plastic cover laterally off the back of the device.
  2. Kindle 1st Generation SD Card Reader Replacement: 2 단계, 이미지 2개 중 1개 Kindle 1st Generation SD Card Reader Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to lift the battery on the side closest to the edge of the device.
    • Unplug the battery from the device by pinching the white connector and pulling.
    • Do not yank the battery or try to disconnect the battery by pulling the wires.
  3. Kindle 1st Generation SD Card Reader Replacement, SD Card Reader: 3 단계, 이미지 1개 중 1개
    • Unscrew eight (8) Phillips #00 screws (3 mm).
  4. Kindle 1st Generation SD Card Reader Replacement: 4 단계, 이미지 2개 중 1개 Kindle 1st Generation SD Card Reader Replacement: 4 단계, 이미지 2개 중 2개
    • Start at one side of the device. Use a plastic opening tool to separate the casing of the device. Slowly work your way around the entire device.
    • Avoid prying between the buttons and the device. This could cause damage to the buttons.
  5. Kindle 1st Generation SD Card Reader Replacement: 5 단계, 이미지 2개 중 1개 Kindle 1st Generation SD Card Reader Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the two (2) Phillips #00 screws (3 mm) which fasten the metal casing shield.
    • Slowly remove the metal casing shield by lifting it and carefully peeling up the tape.
  6. Kindle 1st Generation SD Card Reader Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four (4) Phillips #00 screws (3 mm) which fasten the SD Card Reader.
  7. Kindle 1st Generation SD Card Reader Replacement: 7 단계, 이미지 2개 중 1개 Kindle 1st Generation SD Card Reader Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with a spudger.
    • The flap is connected via a hinge. Once you lift the flap, it will stay up and the cable will be lose. Remember to snap it back down during reassembly.
    • Carefully lift the SD Card Reader vertically from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Samantha Manning
회원 가입일: 06/04/13
787 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 1,978
