소개
Replacing the battery on your Kindle 2 is fairly simple. It only requires removing the back cover and a few screws.
필요한 것
Lay the Kindle face down on a soft cloth to protect its screen.
Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
Slide the gray plastic top piece away from the Kindle's metal casing.
Once the gray plastic top piece is detached from the metal back cover, remove it.
다른 39명이 해당 안내서를 완성하였습니다.
댓글 9개
Easy! Worked well with the tools described. Kudos for making this available, it gave my old Kindle a new breath of life!
An ebay-acquired battery fit perfectly, but failed to reboot the kindle or accept a charge.
the battery looks idential to the Kindale battery to an old analog voltmeter.
I conformed that the kindle terminals were receiving battery voltage.
The replacement guide was just fine, Back to the original battery, which is well past its best-by date!
Thank you so much for the guide! I was able to get my wife’s first Kindle (her favorite) back up and running. Super easy thanks to your guide.
icabod5000 - 답글
I had a heck of time using the spudger. I have found that grabbing the corners and using my thumbs to push the plastic away worked like a champ.
teamhudson - 답글
Thanks for this tip, was successful using the thumb method :)
Rosie A. -
to help get enough grip with my thumbs, I used a piece of old yoga mat to increase friction between thumbs and the top plastic piece
Rosie A. -
For anyone still looking for this in 2020, see my comment here for how to properly remove the back.
Kindle 2 Teardown
Dave76 - 답글
