주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Kindle 2 Motherboard Replacement
필요한 것
  1. Kindle 2 Motherboard Replacement, Battery: 1 단계, 이미지 1/3 Kindle 2 Motherboard Replacement, Battery: 1 단계, 이미지 2/3 Kindle 2 Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Lay the Kindle face down on a soft cloth to protect its screen.
    • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
    • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
    • Slide the gray plastic top piece away from the Kindle's metal casing.
    • Once the gray plastic top piece is detached from the metal back cover, remove it.
  2. Kindle 2 Motherboard Replacement: 2 단계, 이미지 1/2 Kindle 2 Motherboard Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
  3. Kindle 2 Motherboard Replacement: 3 단계, 이미지 1/2 Kindle 2 Motherboard Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
    • Remove the metal casing.
    • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
  4. Kindle 2 Motherboard Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
    • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
  5. Kindle 2 Motherboard Replacement: 5 단계, 이미지 1/2 Kindle 2 Motherboard Replacement: 5 단계, 이미지 2/2
    • Pry upward under the black tab with the spudger to dislodge the battery.
    • Use your fingers to lift the battery out of the device.
  6. Kindle 2 Motherboard Replacement, Wireless Card: 6 단계, 이미지 1/1
    • Rotate the Kindle 180 degrees. Locate the wireless card with the AnyData logo on the top left and the FCC symbol on the right.
    • Use a Phillips #00 screwdriver to remove the two 2mm screws from the wireless card.
  7. Kindle 2 Motherboard Replacement: 7 단계, 이미지 1/1
    • Use the plastic opening tool to wedge underneath the connection and gently pop off the wire cap.
  8. Kindle 2 Motherboard Replacement: 8 단계, 이미지 1/2 Kindle 2 Motherboard Replacement: 8 단계, 이미지 2/2
    • Use your fingers to lift the left end of the wireless card.
    • Pull the card out of the slot.
  9. Kindle 2 Motherboard Replacement, Motherboard: 9 단계, 이미지 1/2 Kindle 2 Motherboard Replacement, Motherboard: 9 단계, 이미지 2/2
    • Remove 16 screws from the midframe.
  10. Kindle 2 Motherboard Replacement: 10 단계, 이미지 1/3 Kindle 2 Motherboard Replacement: 10 단계, 이미지 2/3 Kindle 2 Motherboard Replacement: 10 단계, 이미지 3/3
    • Use the plastic opening tool to push each side of the crimp away from each other. This will open the crimp holding the wire.
    • Use your fingers to lift the wire out of the crimp when there is enough separation between the sides of the crimp.
  11. Kindle 2 Motherboard Replacement: 11 단계, 이미지 1/3 Kindle 2 Motherboard Replacement: 11 단계, 이미지 2/3 Kindle 2 Motherboard Replacement: 11 단계, 이미지 3/3
    • Wedge the opening tool underneath the plastic ribbon and gently pull up to lift the brown connector flap.
    • Squeeze the plastic ribbon gently with the tweezers and pull away from the connector to remove it.
  12. Kindle 2 Motherboard Replacement: 12 단계, 이미지 1/1
    • Locate the next brown connector three inches to the right of the previous connector and repeat Step 10 to remove the plastic ribbon.
  13. Kindle 2 Motherboard Replacement: 13 단계, 이미지 1/2 Kindle 2 Motherboard Replacement: 13 단계, 이미지 2/2
    • Rotate the device 180 degrees and locate a smaller brown connector on the left side of the device.
    • Repeat Step 10.
  14. Kindle 2 Motherboard Replacement: 14 단계, 이미지 1/1
    • Push your finger down on the last plastic ribbon.
    • Slide your finger away from the connector to remove the last ribbon.
  15. Kindle 2 Motherboard Replacement: 15 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the motherboard located around the LAB126 logo.
  16. Kindle 2 Motherboard Replacement: 16 단계, 이미지 1/1
    • Grab the bottom corner of the motherboard and safely remove it from the Kindle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David Scrobonia
회원 가입일: 04/16/13
261 평판
안내서 1개 작성함
Cal Poly, Team 12-32, Amido Spring 2013 Cal Poly, Team 12-32, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G32
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 10
전체 시간: 2,099
