이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Lay the Kindle face down on a soft cloth to protect its screen.
Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
Slide the gray plastic top piece away from the Kindle's metal casing.
Once the gray plastic top piece is detached from the metal back cover, remove it.
Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
Remove the metal casing.
Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
Pry upward under the black tab with the spudger to dislodge the battery.
Use your fingers to lift the battery out of the device.
Use a Phillips #00 screwdriver to remove the two 2mm screws from the wireless card.
Use the plastic opening tool to wedge underneath the connection and gently pop off the wire cap.
Use your fingers to lift the left end of the wireless card.
Pull the card out of the slot.
Use the plastic opening tool to push each side of the crimp away from each other. This will open the crimp holding the wire.
Use your fingers to lift the wire out of the crimp when there is enough separation between the sides of the crimp.
Wedge the opening tool underneath the plastic ribbon and gently pull up to lift the brown connector flap.
Squeeze the plastic ribbon gently with the tweezers and pull away from the connector to remove it.
Locate the next brown connector three inches to the right of the previous connector and repeat Step 10 to remove the plastic ribbon.
Rotate the device 180 degrees and locate a smaller brown connector on the left side of the device.
Repeat Step 10.
Push your finger down on the last plastic ribbon.
Slide your finger away from the connector to remove the last ribbon.
Use a Phillips #00 screwdriver to remove the four 4 mm screws from the motherboard located around the LAB126 logo.
Grab the bottom corner of the motherboard and safely remove it from the Kindle.
다른 한 분이 해당 안내서를 완성하였습니다.
