주요 콘텐츠로 건너뛰기
Kindle 7th Generation Battery Replacement
필요한 것
  1. Kindle 7th Generation Battery Replacement, Front Panel: 1 단계, 이미지 2개 중 1개 Kindle 7th Generation Battery Replacement, Front Panel: 1 단계, 이미지 2개 중 2개
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Kindle 7th Generation Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
  3. Kindle 7th Generation Battery Replacement, Back Panel: 3 단계, 이미지 2개 중 1개 Kindle 7th Generation Battery Replacement, Back Panel: 3 단계, 이미지 2개 중 2개
    • Remove the ten 5.0 mm T5 Torx screws.
    • A magnetized screw mat can help you keep track of your screws.
  4. Kindle 7th Generation Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
  5. Kindle 7th Generation Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Flip the Kindle over, exposing the battery and motherboard.
  6. Kindle 7th Generation Battery Replacement: 6 단계, 이미지 2개 중 1개 Kindle 7th Generation Battery Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the blunted precision tweezers to pinch the ends of the clip securing the battery cord to the motherboard.
    • Gently slide the cord from the motherboard connection.
  7. Kindle 7th Generation Battery Replacement: 7 단계, 이미지 2개 중 1개 Kindle 7th Generation Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry the battery from the backside of the screen.
    • Set the battery aside.
    • The battery has excessive adhesive so this may take some extra effort.
    • If replacing your battery, safely dispose of your damaged battery and use adhesive to insert the new battery.
결론
다른 28명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Abby Roulier
회원 가입일: 02/08/15
1,041 평판
안내서 3개를 작성함
Cal Poly, Team 6-28, Amido Winter 2015 Cal Poly, Team 6-28, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G28
4 회원들
안내서 24개를 작성함
21가이드 댓글
Where can I purchase the battery?
Boon - 답글
Fairly easy to do. Saves a lot of money compared to buying a whole new Kindle :) Thank you for this! A note: I've never seen batteries as...soft as these. Take care when using the removal tool. I could be easy to puncture the battery which could cause a big mess and possibly injury.
Joshua - 답글
Where do I get a new battery from please?
Tracy Armstrong - 답글
The link to buy a replacement battery on amazon is dead. Ideas on an alternate source?
Yagoth - 답글
You can get the batteries on Ebay.
Mike Rayner - 답글
댓글 쓰기
조회 통계:
지난 24시간: 30
지난 7일: 195
지난 30일: 914
전체 시간: 51,640
