주요 콘텐츠로 건너뛰기
Kindle Fire HD 2013 USB and Aux Port Replacement
필요한 것
  1. Kindle Fire HD 2013 USB and Aux Port Replacement, USB and Aux Port: 1 단계, 이미지 3개 중 1개 Kindle Fire HD 2013 USB and Aux Port Replacement, USB and Aux Port: 1 단계, 이미지 3개 중 2개 Kindle Fire HD 2013 USB and Aux Port Replacement, USB and Aux Port: 1 단계, 이미지 3개 중 3개
    • Open up the device by using a plastic opening tool in order to avoid damaging the device.
    • To do so, find the seam along the outer edge of the device and use the plastic tool to pry the back panel up. Doing so may take some force and patience.
    • The USB port is located at the top of the device.
    • The Aux port is located at the bottom of the device.
  2. Kindle Fire HD 2013 USB and Aux Port Replacement: 2 단계, 이미지 2개 중 1개 Kindle Fire HD 2013 USB and Aux Port Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the battery's power ribbon.
    • Use a nylon spudger to disconnect the ribbon from the motherboard.
  3. Kindle Fire HD 2013 USB and Aux Port Replacement: 3 단계, 이미지 1개 중 1개
    • After locating the USB port at the top of the device, remove the (2) 3mm T4 Torx screws.
  4. Kindle Fire HD 2013 USB and Aux Port Replacement: 4 단계, 이미지 3개 중 1개 Kindle Fire HD 2013 USB and Aux Port Replacement: 4 단계, 이미지 3개 중 2개 Kindle Fire HD 2013 USB and Aux Port Replacement: 4 단계, 이미지 3개 중 3개
    • After removing the screws, follow the ribbon to where it connects to the main device.
    • There is a small tab here that must be lifted up in order to allow the ribbon to be removed without damaging it.
    • Once the tab has been opened, gently pull the ribbon out and away. The USB port should now be detached completely.
  5. Kindle Fire HD 2013 USB and Aux Port Replacement: 5 단계, 이미지 1개 중 1개
    • After locating the Aux port at the bottom of the device, remove the (2) 3mm T4 Torx screws.
  6. Kindle Fire HD 2013 USB and Aux Port Replacement: 6 단계, 이미지 3개 중 1개 Kindle Fire HD 2013 USB and Aux Port Replacement: 6 단계, 이미지 3개 중 2개 Kindle Fire HD 2013 USB and Aux Port Replacement: 6 단계, 이미지 3개 중 3개
    • There is a tab here that must be opened before the part can be removed. Use the nylon spudger or a finger nail to lift the tab open.
    • Once the tab is open, gently remove the ribbon. The Aux port should now be detached completely.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
aaa
회원 가입일: 10/06/16
733 평판
안내서 5개를 작성함
USF Tampa, Team 2-3, Sullivan Fall 2016 USF Tampa, Team 2-3, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G3
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 1,202
