소개
Removing the back panel of the Kindle Fire HD 6 is very important, because you can't access any of the other components until you remove the back panel. In this guide, we'll cover how to remove this panel so that you can replace the components inside.
필요한 것
Place the device face down on a clean cloth or another smooth surface.
Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
Maneuver the tool around the device until the back unclips from the front panel.
다른 2명이 해당 안내서를 완성하였습니다.
