주요 콘텐츠로 건너뛰기
Kindle Fire HD 6 Back Panel Replacement
필요한 것
  1. Kindle Fire HD 6 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
  2. Kindle Fire HD 6 Back Panel Replacement: 2 단계, 이미지 1/2 Kindle Fire HD 6 Back Panel Replacement: 2 단계, 이미지 2/2
    • Carefully separate the back panel from the rest of the device internals.
결론
다른 2명이 해당 안내서를 완성하였습니다.
000
회원 가입일: 01/11/15
964 평판
안내서 1개 작성함
Cal Poly, Team 70-4, Forte Winter 2015 Cal Poly, Team 70-4, Forte Winter 2015 회원
CPSU-FORTE-W15S70G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 1,986
