주요 콘텐츠로 건너뛰기
Kindle Fire HD 6 Rear Facing Camera Replacement
필요한 것
  1. Kindle Fire HD 6 Rear Facing Camera Replacement, Back Panel: 1 단계, 이미지 1/1
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
  2. Kindle Fire HD 6 Rear Facing Camera Replacement: 2 단계, 이미지 1/2 Kindle Fire HD 6 Rear Facing Camera Replacement: 2 단계, 이미지 2/2
    • Carefully separate the back panel from the rest of the device internals.
  3. Kindle Fire HD 6 Rear Facing Camera Replacement, Rear Facing Camera: 3 단계, 이미지 1/1
    • Unscrew the two 3.5mm T5 Torx Screws from the top of the camera.
  4. Kindle Fire HD 6 Rear Facing Camera Replacement: 4 단계, 이미지 1/3 Kindle Fire HD 6 Rear Facing Camera Replacement: 4 단계, 이미지 2/3 Kindle Fire HD 6 Rear Facing Camera Replacement: 4 단계, 이미지 3/3
    • Be careful not to damage the camera lens as you remove the camera.
    • Gently pull the camera up and out of the device. As you pull, unclip the black and white connector with orange tape by popping it off at its base.
결론
Cassandra Beck
회원 가입일: 01/13/15
885 평판
안내서 5개 작성하였습니다
Cal Poly, Team 70-4, Forte Winter 2015 Cal Poly, Team 70-4, Forte Winter 2015 회원
CPSU-FORTE-W15S70G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 906
