주요 콘텐츠로 건너뛰기
Kindle Fire HD 6 Speaker Replacement
필요한 것
  1. Kindle Fire HD 6 Speaker Replacement, Back Panel: 1 단계, 이미지 1/1
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
  2. Kindle Fire HD 6 Speaker Replacement: 2 단계, 이미지 1/2 Kindle Fire HD 6 Speaker Replacement: 2 단계, 이미지 2/2
    • Carefully separate the back panel from the rest of the device internals.
  3. Kindle Fire HD 6 Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Unscrew the two 3.5mm T5 Torx screws at the base of the speaker.
  4. Kindle Fire HD 6 Speaker Replacement: 4 단계, 이미지 1/2 Kindle Fire HD 6 Speaker Replacement: 4 단계, 이미지 2/2
    • Unclip the speaker wire that runs up the side of the battery and clips into the motherboard next to the battery connector. Gently pull it straight up.
  5. Kindle Fire HD 6 Speaker Replacement: 5 단계, 이미지 1/2 Kindle Fire HD 6 Speaker Replacement: 5 단계, 이미지 2/2
    • Lift the speaker out of the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Cassandra Beck
회원 가입일: 01/13/15
885 평판
안내서 5개 작성하였습니다
Cal Poly, Team 70-4, Forte Winter 2015 Cal Poly, Team 70-4, Forte Winter 2015 회원
CPSU-FORTE-W15S70G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 696
