주요 콘텐츠로 건너뛰기
Kindle Fire HD Front Facing Camera Replacement
필요한 것
  1. Kindle Fire HD Front Facing Camera Replacement, Open the Kindle: 1 단계, 이미지 3개 중 1개 Kindle Fire HD Front Facing Camera Replacement, Open the Kindle: 1 단계, 이미지 3개 중 2개 Kindle Fire HD Front Facing Camera Replacement, Open the Kindle: 1 단계, 이미지 3개 중 3개
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Lift up until you hear a slight popping noise.
    • Repeat along the perimeter of the device to release the clips securing the case halves to each other. Remove the back cover.
    • The Kindle Fire could possibly have tape on the inside. Check for tape before removing the back cover.
  2. Kindle Fire HD Front Facing Camera Replacement: 2 단계, 이미지 1개 중 1개
    • If your device has copper tape attached to the battery, carefully peel it off the battery.
  3. Kindle Fire HD Front Facing Camera Replacement: 3 단계, 이미지 2개 중 1개 Kindle Fire HD Front Facing Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the antenna cable connector which is easier to find if you look for the gold tipped black wire that surrounds the battery.
    • Lift and pull up the antenna connector and the antenna cable that surrounds the battery
  4. Kindle Fire HD Front Facing Camera Replacement, Remove Screws: 4 단계, 이미지 3개 중 1개 Kindle Fire HD Front Facing Camera Replacement, Remove Screws: 4 단계, 이미지 3개 중 2개 Kindle Fire HD Front Facing Camera Replacement, Remove Screws: 4 단계, 이미지 3개 중 3개
    • Locate and unscrew the four 3 mm screws using the Phillips #00 screwdriver.
    • Unscrew the one T5 Torx screw using the special T5 Torx screwdriver head.
    • The 2 mm T5 Torx screw is located on the motherboard near the antenna clip.
    • If you aren't equipped with the T5 Torx screwdriver, you could try using your fingers, although it will be very difficult to remove it.
  5. Kindle Fire HD Front Facing Camera Replacement, Detach Cable: 5 단계, 이미지 2개 중 1개 Kindle Fire HD Front Facing Camera Replacement, Detach Cable: 5 단계, 이미지 2개 중 2개
    • Detach the plastic piece that connects the wires to the motherboard using the plastic opening tool.
  6. Kindle Fire HD Front Facing Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the battery out of the device with your finger or the plastic opening tool.
  7. Kindle Fire HD Front Facing Camera Replacement, Front Facing Camera: 7 단계, 이미지 2개 중 1개 Kindle Fire HD Front Facing Camera Replacement, Front Facing Camera: 7 단계, 이미지 2개 중 2개
    • After removing the battery, locate the camera.
  8. Kindle Fire HD Front Facing Camera Replacement: 8 단계, 이미지 2개 중 1개 Kindle Fire HD Front Facing Camera Replacement: 8 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to carefully lift the camera up.
    • Now you may lift the camera out of your device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Matthew Hodgdon
회원 가입일: 03/03/15
1,366 평판
안내서 2개를 작성함
Sam Houston State, Team 11-2, Blackburne Winter 2015 Sam Houston State, Team 11-2, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G2
3 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 21
전체 시간: 1,579
