소개
If your Kindle Fire HDX 7” tablet is staying bright when the night falls and dark when the suns out, the ambient light sensor may be busted.
First check the settings and make sure that auto brightness is turned on, if it is, follow this guide to replace it yourself.
필요한 것
Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
Pry up the ambient light sensor press-fit connector from the motherboard with the flat end of a spudger.
거의 끝나갑니다!
결론
