주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle Fire Motherboard Replacement
필요한 것
    1. Kindle Fire Motherboard Replacement, Back Case: 1 단계, 이미지 3개 중 1개 Kindle Fire Motherboard Replacement, Back Case: 1 단계, 이미지 3개 중 2개 Kindle Fire Motherboard Replacement, Back Case: 1 단계, 이미지 3개 중 3개
      • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
      • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
      • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
      • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
      댓글 쓰기
    2. Kindle Fire Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
      댓글 쓰기
    1. Kindle Fire Motherboard Replacement, Battery: 3 단계, 이미지 3개 중 1개 Kindle Fire Motherboard Replacement, Battery: 3 단계, 이미지 3개 중 2개 Kindle Fire Motherboard Replacement, Battery: 3 단계, 이미지 3개 중 3개
      • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
      • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
      댓글 쓰기
    2. Kindle Fire Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      • Repeat the process from the previous step to free the left battery cell.
      댓글 쓰기
    3. Kindle Fire Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Kindle Fire Motherboard Replacement: 5 단계, 이미지 2개 중 2개
      • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
      • Pull the battery out of the Kindle Fire.
      댓글 쓰기
    1. Kindle Fire Motherboard Replacement, Speaker Cable: 6 단계, 이미지 3개 중 1개 Kindle Fire Motherboard Replacement, Speaker Cable: 6 단계, 이미지 3개 중 2개 Kindle Fire Motherboard Replacement, Speaker Cable: 6 단계, 이미지 3개 중 3개
      • Peel the tape on the upper-left IC that is securing the speaker cable.
      • Use the flat end of a spudger to push the speaker connector out of its socket.
      • Deroute the speaker cable so that it will not interfere with the motherboard.
      댓글 쓰기
    1. Kindle Fire Motherboard Replacement, Motherboard: 7 단계, 이미지 3개 중 1개 Kindle Fire Motherboard Replacement, Motherboard: 7 단계, 이미지 3개 중 2개 Kindle Fire Motherboard Replacement, Motherboard: 7 단계, 이미지 3개 중 3개
      • Remove the two 2.3 mm Phillips #00 screws from the touchscreen controller.
      • Use a plastic opening tool to release the touchscreen controller connector.
      • Gently remove the touchscreen controller by lifting it up and to the right.
      • Be careful not to rip the ribbon cable in doing so.
      댓글 쓰기
    2. Kindle Fire Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Kindle Fire Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Kindle Fire Motherboard Replacement: 8 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use a plastic opening tool to flip open the power button ZIF connector.
      • This connector will not be removed until the motherboard is free.
      • Flip open the ambient light sensor ZIF socket with a plastic opening tool.
      • Use a pair of tweezers to pull the blue tab on the ambient light sensor cable to remove it from its socket.
      댓글 쓰기
    3. Kindle Fire Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Kindle Fire Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Kindle Fire Motherboard Replacement: 9 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to lift up and disconnect the display data cable.
      • Lift up on the antenna connector with a plastic opening tool to disconnect it.
      • De-route the antenna cable.
      댓글 쓰기
    4. Kindle Fire Motherboard Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the six 2.6 mm Phillips #00 screws securing the motherboard to the frame.
      댓글 쓰기
    5. Kindle Fire Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Kindle Fire Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Kindle Fire Motherboard Replacement: 11 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to gently lever up the bottom side of the motherboard to free from the adhesive on its underside.
      • Lever the top side of the motherboard up with a plastic opening tool until it comes free.
      • Lift the motherboard out of the Kindle Fire, making sure that the power button cable from step 8 comes free from its connector.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 64명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jake Devincenzi
회원 가입일: 04/18/11
119,403 평판
안내서 57개를 작성함
5가이드 댓글
These are excellent instructions. Unfortunately, it's impossible to find a motherboard for a first generation Kindle KINDLE FIRE 31KC1MB0090 for the D01400. I just spent an hour searching the Internet including, eBay, powerbookmedic.com and Pronto.com. PowerBookmedic advertises the motherboard but they are out of stock. If anyone has any sources, I would greatly appreciated it.
pcanady1998 - 답글 공유
I did it! I removed the Kindle Fire 7" motherboard, replaced the USB connector with one bought from a vendor on eBay, and then reassembled the Kindle with a fully functional USB connector. Your guide made it an easy project for a couple hours on a Sunday afternoon.
Soldering the fine-pitched connector is probably not for the faint of heart, but I have a good temperature controlled soldering station and a lighted magnifier that made the task eminently do-able.
I would not have tackled this project without your step-by-step guide and Plastic Opening Tools.
Thanks!
/john
jkeefe1 - 답글 공유
Where did you get the connector. If you can send me a link for the connector. I have the same issue.
Kevin
rkevinball - 답글 공유
Mon kindle fire ne s'allume pas car lorsqu'il affiche le logo directement un écran rouge affiche et puis rien
NICEFORT - 답글 공유
I didn’t rip the sensor ribbon but the touch screen isnt working. It’s all connected as should be
zodiemichelle - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 19
지난 30일: 96
전체 시간: 153,564
