소개
Use this guide to help you replace the speakers in the Amazon Kindle Fire.
필요한 것
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
Repeat the process from the previous step to free the left battery cell.
The CPU got extremely hot and just now getting repaired 5 days or so
I can't get the battery to charge
Peel the tape on the upper-left IC that is securing the speaker cable.
Use the flat end of a spudger to push the speaker connector out of its socket.
Deroute the speaker cable.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
I replaced the speakers and now my screen is black. I hear sounds but no picture. Any suggestions???
Where can I buy a battery for my kindle fire
nannyto2 - 답글
Try EBay or Amazon. make sure you get the right battery for your Kindle , one is for a Kindle HD and the older version........both are 7 ".
vvenona1954 - 답글
Remember to remove any sd card first!!! Snapped mine in half.
lucy_lady_bug - 답글
I have the first kindle that came out and it doesn't have the same setup how can I open the back of my kindle?
Kris Sanders - 답글
