주요 콘텐츠로 건너뛰기
Kindle Fire Speaker Assembly Replacement
필요한 것
  1. Kindle Fire Speaker Assembly Replacement, Back Case: 1 단계, 이미지 1/3 Kindle Fire Speaker Assembly Replacement, Back Case: 1 단계, 이미지 2/3 Kindle Fire Speaker Assembly Replacement, Back Case: 1 단계, 이미지 3/3
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
    Where can I buy a battery for my kindle fire
    nannyto2 - 답글
    Try EBay or Amazon. make sure you get the right battery for your Kindle , one is for a Kindle HD and the older version........both are 7 ".
    vvenona1954 - 답글
    Remember to remove any sd card first!!! Snapped mine in half.
    lucy_lady_bug - 답글
    I have the first kindle that came out and it doesn't have the same setup how can I open the back of my kindle?
    Kris Sanders - 답글
  2. Kindle Fire Speaker Assembly Replacement: 2 단계, 이미지 1/1
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
    Mine has another plastic pc over the m.etal plate
    Keith Long - 답글
  3. Kindle Fire Speaker Assembly Replacement, Battery: 3 단계, 이미지 1/3 Kindle Fire Speaker Assembly Replacement, Battery: 3 단계, 이미지 2/3 Kindle Fire Speaker Assembly Replacement, Battery: 3 단계, 이미지 3/3
    • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
    • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
  4. Kindle Fire Speaker Assembly Replacement: 4 단계, 이미지 1/1
    • Repeat the process from the previous step to free the left battery cell.
    The CPU got extremely hot and just now getting repaired 5 days or so
    Kelli Sabashion - 답글
    I can't get the battery to charge
  5. Kindle Fire Speaker Assembly Replacement: 5 단계, 이미지 1/2 Kindle Fire Speaker Assembly Replacement: 5 단계, 이미지 2/2
    • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
    • Pull the battery out of the Kindle Fire.
  6. Kindle Fire Speaker Assembly Replacement, Speaker Assembly: 6 단계, 이미지 1/3 Kindle Fire Speaker Assembly Replacement, Speaker Assembly: 6 단계, 이미지 2/3 Kindle Fire Speaker Assembly Replacement, Speaker Assembly: 6 단계, 이미지 3/3
    • Peel the tape on the upper-left IC that is securing the speaker cable.
    • Use the flat end of a spudger to push the speaker connector out of its socket.
    • Deroute the speaker cable.
  7. Kindle Fire Speaker Assembly Replacement: 7 단계, 이미지 1/2 Kindle Fire Speaker Assembly Replacement: 7 단계, 이미지 2/2
    • Remove the two 3.3 mm Phillips #00 screws securing the speakers to the Kindle Fire.
    • Lift the speakers out of the Kindle Fire.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Phillip Takahashi
회원 가입일: 08/22/11
86,704 평판
안내서 87개 작성하였습니다
댓글 2개
It was easier for me to start taking the back off near the speakers.
Thanks for the post ... very helpful!
Gregory - 답글
I replaced the speakers and now my screen is black. I hear sounds but no picture. Any suggestions???
Ann Marie Marciano - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 6,188
