주요 콘텐츠로 건너뛰기
Kindle Paperwhite 2nd Generation Battery Replacement
필요한 것
  1. Kindle Paperwhite 2nd Generation Battery Replacement, Battery: 1 단계, 이미지 1/2 Kindle Paperwhite 2nd Generation Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
    • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
  2. Kindle Paperwhite 2nd Generation Battery Replacement: 2 단계, 이미지 1/2 Kindle Paperwhite 2nd Generation Battery Replacement: 2 단계, 이미지 2/2
    • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Battery Replacement: 3 단계, 이미지 1/1
    • Carefully remove the mid-frame from the back cover.
  4. Kindle Paperwhite 2nd Generation Battery Replacement: 4 단계, 이미지 1/2 Kindle Paperwhite 2nd Generation Battery Replacement: 4 단계, 이미지 2/2
    • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
  5. Kindle Paperwhite 2nd Generation Battery Replacement: 5 단계, 이미지 1/1
    • Carefully lift the battery and remove it from the device.
결론
다른 25명이 해당 안내서를 완성하였습니다.
Tyler Davis
회원 가입일: 09/15/16
1,598 평판
안내서 5개 작성하였습니다
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G2
4 회원들
안내서 7개 작성하였습니다
댓글 7개
Do you have a source for the battery itself? Thank you.
mattstonecash - 답글
I’ve done this on two different Kindles with the same result: dead kindle. No matter how long it stays on the charger, the light stays amber. Screen will not change. Hard reset seems to do nothing; the light flashes, but no change. One Paperwhite even got a new motherboard. This is crazy! Is it possible to fix one, do I have to just buy another!?
Adam Britt - 답글
I'm probably 7 years too late but this was the case with one I got from Goodwill and plugging it into a higher amperage charger (2.4A) seemed to do the trick. When you plug it in it charges until there is enough power for it to boot up and when that happens it ends up draining the little bit that was there so it just gets stuck in a loop. You just have to give it more power to work with.
Ellis Bowser -
Hi Adam,
I have the same issue, the light is orange but the Kindle won’t turn on. I ordered the battery at www.batteryupgrade.com. But they have some misleading info on their website so they sent me the wrong battery even if it states that it supports Kindle Paperwhite 2012. Check the connections on original and on the new battery. In my case the battery looks the same, but the connections doesn’t. Now I’m waiting for the new one …
Regards.
Andrej Mihelic - 답글
Did replacement of battery help you to resolve problem?
behemothkat -
댓글 쓰기
조회 통계:
24 시간 전: 13
7일 전: 119
30일 전: 427
전체 시간: 18,691
