주요 콘텐츠로 건너뛰기
Kindle Paperwhite 2nd Generation Screen Replacement
필요한 것
  1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
  2. Kindle Paperwhite 2nd Generation Screen Replacement: 2 단계, 이미지 2개 중 1개 Kindle Paperwhite 2nd Generation Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully lift and remove the mid-frame.
  4. Kindle Paperwhite 2nd Generation Screen Replacement: 4 단계, 이미지 1개 중 1개
    • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tyler Davis
회원 가입일: 09/15/16
1,869 평판
안내서 5개를 작성함
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G2
4 회원들
안내서 17개를 작성함
3가이드 댓글
My opening tool is orange. Will this still work for me?
FoxRunTime - 답글
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - 답글
Did this work Liam?
Ben Lowdon -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 28
지난 30일: 129
전체 시간: 14,309
