주요 콘텐츠로 건너뛰기
Kindle Paperwhite 3rd Generation Motherboard Replacement
필요한 것
  1. Kindle Paperwhite 3rd Generation Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Kindle Paperwhite 3rd Generation Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Kindle Paperwhite 3rd Generation Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Ensure that the device is turned off before beginning.
    • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
    • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
  2. Kindle Paperwhite 3rd Generation Motherboard Replacement, Using caution: 2 단계, 이미지 3개 중 1개 Kindle Paperwhite 3rd Generation Motherboard Replacement, Using caution: 2 단계, 이미지 3개 중 2개 Kindle Paperwhite 3rd Generation Motherboard Replacement, Using caution: 2 단계, 이미지 3개 중 3개
    • Use extreme caution when prying up the bezel. Be careful not to allow your pry tool to fall underneath the display. Look under the cover as you work, separating the display from the adhesive of the bezel.
    • You want to make sure your separator goes through both sides of the bezel over top of the display.
    • The second photo is the layer you want your tool to pass through safely.
    • The third photo is an example of what can go wrong. If this happens your digitizer layer will misread touches and the display is permanently damaged.
  3. Kindle Paperwhite 3rd Generation Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Kindle Paperwhite 3rd Generation Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
  4. Kindle Paperwhite 3rd Generation Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Gently lift the mid-frame out of the case with your hands.
    • Lift the side opposite of the power button out first.
  5. Kindle Paperwhite 3rd Generation Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Kindle Paperwhite 3rd Generation Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
  6. Kindle Paperwhite 3rd Generation Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Gently lift the battery from the frame.
  7. Kindle Paperwhite 3rd Generation Motherboard Replacement, Motherboard: 7 단계, 이미지 1개 중 1개
    • Flip the black latch with a plastic opening tool, and then gently pull back the orange ribbon cable.
  8. Kindle Paperwhite 3rd Generation Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Flip the tiny off-white latch with angled precision tweezers toward the direction of the battery.
    • Gently peel back the orange ribbon cable.
  9. Kindle Paperwhite 3rd Generation Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Kindle Paperwhite 3rd Generation Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Peel back the orange ribbon cable near the battery.
    • Flip the tiny black latch with angled precision tweezers toward the closest edge of the device.
  10. Kindle Paperwhite 3rd Generation Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Peel back the white connector with your fingers.
  11. Kindle Paperwhite 3rd Generation Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Kindle Paperwhite 3rd Generation Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Unscrew the six 3.0 mm Phillips #000 screws surrounding the motherboard.
    • Unscrew the one 2.5 mm Phillips #000 screw.
    • There is a little metal plate underneath the 2.5 mm screw and washers under four of the 3.0 mm screws.
  12. Kindle Paperwhite 3rd Generation Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to lift the motherboard upwards from the frame.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Micah Smart
회원 가입일: 02/10/16
3,400 평판
안내서 3개를 작성함
USF Tampa, Team 14-3, Lacy Spring 2016 USF Tampa, Team 14-3, Lacy Spring 2016 회원
USFT-LACY-S16S14G3
4 회원들
안내서 14개를 작성함
6가이드 댓글
how do I fix my loose charging port?
angusc - 답글
how do i fix my loose charging port connection
angusc - 답글
Where can I buy a kindle paper white, new mother board?
Lorraine - 답글
Tip, heat the front bezel to soften the glue.
KAASKOP3000 - 답글
I totally know how to fix my kindle but I don’t know where to get the part. I broke the tip to the ribbon cable for the only %#*@ button on the device. do they sell those here?
Corry Newton - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 60
지난 30일: 248
전체 시간: 13,854
