소개
Next to the battery is the 3G unit. However, in the
models that are WiFi only, there will instead be a plastic placeholder instead. The replacement instructions for both are identical.
필요한 것
동영상 개요
Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
Next, gently lift the 3G assembly with a Spudger or your fingers.
Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Hey, thanks for your guide!
I, however, have one question, maybe I misunderstood - is it possible to add a 3G module to a kindle touch that didn't have one installed by default?
Would it work?
You would need to add more than just a 3G module - there’s a slot for a SIM-card tray and special Amazon SIM that are missing from non-3G Kindle Touches. I don’t know if there would be any software changes that would need making.
