소개
Use this guide to replace an old or faulty Amazon Kindle Touch battery. The battery may be due for replacement if your Kindle runs out of power quickly, won’t work unless plugged in, or won’t charge.
Make sure the device is powered off and disconnected from all external power sources before beginning this process. Please dispose of electronic waste responsibly.
필요한 것
Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
다른 18명이 해당 안내서를 완성하였습니다.
