소개
This guide will cover how to remove and replace the bezel on a Kindle Touch and requires using a plastic opening tool and PH00 screwdriver.
필요한 것
Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
