주요 콘텐츠로 건너뛰기
Kindle Touch Bezel Replacement
필요한 것
  1. Kindle Touch Bezel Replacement, Back Cover: 1 단계, 이미지 1/3 Kindle Touch Bezel Replacement, Back Cover: 1 단계, 이미지 2/3 Kindle Touch Bezel Replacement, Back Cover: 1 단계, 이미지 3/3
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
    Wear work gloves as the tool can easily slip and stab you in the hand.
    BRUCE - 답글
    The clips aren't all the same; the side clips are slide-locks rather than press-locks.
    Use the Opening Tool to unclip the clips along the bottom edge. This will allow the lid to slide towards the top, releasing the side clips and allowing the lid to be lifted off.
    When reassembling, slide the lid upwards while pressing the sides to re-engage the side clips, then press the bottom edge to lock it into place.
    jimf - 답글
  2. Kindle Touch Bezel Replacement: 2 단계, 이미지 1/2 Kindle Touch Bezel Replacement: 2 단계, 이미지 2/2
    • Gently lift the bottom and slide the panel off.
    There are four tabs on each side.The two nearest the top are open at the top, hence they slide out (back towards the power connector end.
    This is important in the reassembly stage:
    1. Align the back cover about 0.75 cm away from the top
    2. Hold the top half of the cover flat against the unit, and flex the cover away from the case a little at the bottom
    3. Slide the top and the first two clips parallel to the case
    4. snap the remaining bottom clips in place
    John Haywood - 답글
  3. Kindle Touch Bezel Replacement, Bezel: 3 단계, 이미지 1/2 Kindle Touch Bezel Replacement, Bezel: 3 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
  4. Kindle Touch Bezel Replacement: 4 단계, 이미지 1/3 Kindle Touch Bezel Replacement: 4 단계, 이미지 2/3 Kindle Touch Bezel Replacement: 4 단계, 이미지 3/3
    • Use the plastic opening tool to pry the bezel from the top and sides
    • The bottom of the bezel will be glued, so be careful when sliding the clips out.
    • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jerome Narine
회원 가입일: 01/20/15
221 평판
안내서 1개 작성함
USF Tampa, Team 19-5, Blackwell Winter 2015 USF Tampa, Team 19-5, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S19G5
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
I want to paint The bezel white. Will it come back and fit perfectly after the removal I have to make?
denianyc - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 32
전체 시간: 3,023
