이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If you have damage to the front plate,screen or need access to the screws behind the plate, this guide will tell you how to do so.
필요한 것
Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
Remove the six 4 mm screws in order to access the front plate. Use a Phillips #00 screwdriver.
Use a plastic opening tool to pry the top three sides of the bezel. Since there is glue under the bezel, gently pivot the face at the bottom off the Kindle and slide the clips out.
다른 4명이 해당 안내서를 완성하였습니다.
