이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
Using the flat end of your spudger, gently pry the battery up and remove it.
Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
Use the pointy end of your Spudger to separate the Speaker's connector from the motherboard on both sides.
The speakers are held down solely with contact adhesive, so use your Spudger to pry them from the support board.
