주요 콘텐츠로 건너뛰기
Kindle Voyage Ambient Light Sensor Replacement
필요한 것
  1. Kindle Voyage Ambient Light Sensor Replacement, Back Panel: 1 단계, 이미지 1/2 Kindle Voyage Ambient Light Sensor Replacement, Back Panel: 1 단계, 이미지 2/2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Ambient Light Sensor Replacement: 2 단계, 이미지 1/1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Ambient Light Sensor Replacement: 3 단계, 이미지 1/3 Kindle Voyage Ambient Light Sensor Replacement: 3 단계, 이미지 2/3 Kindle Voyage Ambient Light Sensor Replacement: 3 단계, 이미지 3/3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Ambient Light Sensor Replacement: 4 단계, 이미지 1/2 Kindle Voyage Ambient Light Sensor Replacement: 4 단계, 이미지 2/2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Ambient Light Sensor Replacement, Wifi Antenna: 5 단계, 이미지 1/2 Kindle Voyage Ambient Light Sensor Replacement, Wifi Antenna: 5 단계, 이미지 2/2
    • Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture.
    • Use the same driver to remove the two 2.5 mm screws.
  6. Kindle Voyage Ambient Light Sensor Replacement: 6 단계, 이미지 1/3 Kindle Voyage Ambient Light Sensor Replacement: 6 단계, 이미지 2/3 Kindle Voyage Ambient Light Sensor Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using the tweezers, undo the attached clip.
    • Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head.
    • You should now be able to simply take the WiFi bar off of the device.
  7. Kindle Voyage Ambient Light Sensor Replacement, Ambient Light Sensor: 7 단계, 이미지 1/2 Kindle Voyage Ambient Light Sensor Replacement, Ambient Light Sensor: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Gently remove the connector to the motherboard using tweezers.
    • Continue to carefully pull the rest of the connector from the adhesive connecting it to the Voyage.
    • Detach sensor from the top using fingers
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sean Yap
회원 가입일: 01/22/15
1,351 평판
안내서 6개 작성하였습니다
Cal Poly, Team 19-12, Maness Winter 2015 Cal Poly, Team 19-12, Maness Winter 2015 회원
CPSU-MANESS-W15S19G12
5 회원들
안내서 10개 작성하였습니다
댓글 한 개
If i do this wiithout putting the lightsensor back on, can i then use the kindle without light ?
Best regards
Lasse
Beck - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 25
전체 시간: 2,356
