소개
Vibration is a useful tool to ensure the user that a device is responding to the press of a button. This guide shows how to replace the vibrator in a Kindle Voyage should the device fail to vibrate properly.
필요한 것
Insert a plastic opening tool between the plastic panel shown on the device.
Use the tool to pry the plastic away from the device.
댓글 한 개
OK, the procedure seems straightforward enough, but you say “no parts required” when you actually *do* need to buy the replacement parts for the pieces that are no longer functioning. Where can you buy these parts?
