주요 콘텐츠로 건너뛰기
Kingston HyperX CloudX Speaker Sponge Replacement
필요한 것
  1. Kingston HyperX CloudX Speaker Sponge Replacement, Speaker Sponge: 1 단계, 이미지 1/1
    • Remove the ear cushion from the earphone.
  2. Kingston HyperX CloudX Speaker Sponge Replacement: 2 단계, 이미지 1/2 Kingston HyperX CloudX Speaker Sponge Replacement: 2 단계, 이미지 2/2
    • Remove four 11.2 mm screws from the earpiece using a Phillips #00 screwdriver.
  3. Kingston HyperX CloudX Speaker Sponge Replacement: 3 단계, 이미지 1/2 Kingston HyperX CloudX Speaker Sponge Replacement: 3 단계, 이미지 2/2
    • Use a spudger to pry the top plate away from the motherboard.
    • There will be a groove in between the two plates to insert the spudger.
  4. Kingston HyperX CloudX Speaker Sponge Replacement: 4 단계, 이미지 1/1
    • Use the metal spudger tool to scrape off the old foam pad and any remaining glue.
    • The plate does not have to be completely clean after removal, just clean enough to securely attach the new sponge.
  5. Kingston HyperX CloudX Speaker Sponge Replacement: 5 단계, 이미지 1/1
    • Line the edge of the headphone plate where the original pad was with superglue.
    • Press the new sponge into the glue and allow it to dry fully.
    • The new sponge may need to be cut to size in order to fit on the headphone plate.
    • Make sure the glue is completely dry before reassembling your device. Failure to do this may result in damage of your device.
결론
Kosie
회원 가입일: 03/01/23
121 평판
안내서 1개 작성함
University of Delaware, Team 12-4, McGuire Spring 2023 University of Delaware, Team 12-4, McGuire Spring 2023 회원
UD-MCGUIRE-S23S12G4
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 82
