주요 콘텐츠로 건너뛰기
Kirby G5 Vacuum Belt Replacement
필요한 것
  1. Kirby G5 Vacuum Belt Replacement, Vacuum Belt: 1 단계, 이미지 1/1
    • Place the vacuum at an angle most comfortable and easy to access with the bottom facing upwards.
  2. Kirby G5 Vacuum Belt Replacement: 2 단계, 이미지 1/2 Kirby G5 Vacuum Belt Replacement: 2 단계, 이미지 2/2
    • Remove the three screws holding the base plate to the body of the vacuum using a flat head screwdriver.
    • Place the plate to the side.
  3. Kirby G5 Vacuum Belt Replacement: 3 단계, 이미지 1/1
    • Simply slide the roller out of the vacuum.
    • The belt is attached to the roller on either side.
  4. Kirby G5 Vacuum Belt Replacement: 4 단계, 이미지 1/2 Kirby G5 Vacuum Belt Replacement: 4 단계, 이미지 2/2
    • Slide the vacuum belt out from beneath the wheel holding it in place.
  5. Kirby G5 Vacuum Belt Replacement: 5 단계, 이미지 1/1
    • Insert your new belt and pop the roller back into place.
  6. Kirby G5 Vacuum Belt Replacement: 6 단계, 이미지 1/2 Kirby G5 Vacuum Belt Replacement: 6 단계, 이미지 2/2
    • Secure the plate once again until it clicks into the made grooves.
    • Secure the three screws until tightened.
결론
Make sure to test the vacuum and securely tighten all screws. With that, you’re good to go!
다른 한 분이 해당 안내서를 완성하였습니다.
Gina Trojano
회원 가입일: 04/22/21
157 평판
안내서 1개 작성함
UMass Dartmouth, Team S2-G23, Sinclaire Spring 2021 UMass Dartmouth, Team S2-G23, Sinclaire Spring 2021 회원
UMASSD-SINCLAIRE-S21S2G23
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 59
전체 시간: 1,088
