소개
In this guide, I will demonstrate how to replace their broken kitchen drawer mounts. This issue can be very common if drawers were not built with quality material when building the house. To get the material needed you can take in your broken track or mount into a hardware store and find the correct size. This is a quick and easy repair that will take little time and basic knowledge of repairs/tools.
필요한 것
Now that your repair is done make sure your drawer is sliding smoothly if not you will need to remove it and clean the tracks. Another thing to look for is if the tracks are perfectly aligned if not you can go back in and fix them by following the same steps again.
다른 한 분이 해당 안내서를 완성하였습니다.
