주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kitchen Sink Basket Strainer Replacement
필요한 것
  1. Kitchen Sink Basket Strainer Replacement, Basket Strainer: 1 단계, 이미지 1개 중 1개
    • Shut off the hot and cold water supply valves under the sink.
    • Turn the handles clockwise and make sure the water is off before moving on.
  2. Kitchen Sink Basket Strainer Replacement: 2 단계, 이미지 2개 중 1개 Kitchen Sink Basket Strainer Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the stopper from the basket strainer by lifting it out.
  3. Kitchen Sink Basket Strainer Replacement: 3 단계, 이미지 2개 중 1개 Kitchen Sink Basket Strainer Replacement: 3 단계, 이미지 2개 중 2개
    • Loosen the trap adapter nut under the sink.
    • Use the pliers and turn counterclockwise to loosen the nut.
  4. Kitchen Sink Basket Strainer Replacement: 4 단계, 이미지 2개 중 1개 Kitchen Sink Basket Strainer Replacement: 4 단계, 이미지 2개 중 2개
    • Loosen the tailpiece nut under the basket strainer.
  5. Kitchen Sink Basket Strainer Replacement: 5 단계, 이미지 2개 중 1개 Kitchen Sink Basket Strainer Replacement: 5 단계, 이미지 2개 중 2개
    • Loosen the nut of the basket strainer.
  6. Kitchen Sink Basket Strainer Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the basket strainer from the sink by lifting it out.
  7. Kitchen Sink Basket Strainer Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the tailpiece from the trap adaptor by lifting it out.
    • Keep the trap adapter nut and the nylon slip washer aside.
    • The trap adapter nut and nylon slip washer are shown in the image. The nylon slip is within the trap adaptor.
  8. Kitchen Sink Basket Strainer Replacement: 8 단계, 이미지 2개 중 1개 Kitchen Sink Basket Strainer Replacement: 8 단계, 이미지 2개 중 2개
    • Clean the sink opening and install a new basket strainer and the tailpiece.
    • Image 2 shows all the pieces that should be included in your new kit.
  9. Kitchen Sink Basket Strainer Replacement: 9 단계, 이미지 1개 중 1개
    • Slide the old trap adaptor nut and nylon slip washer over the tailpiece.
  10. Kitchen Sink Basket Strainer Replacement: 10 단계, 이미지 1개 중 1개
    • Install the tailpiece into the trap adaptor with the tailpiece washer inserted on top.
  11. Kitchen Sink Basket Strainer Replacement: 11 단계, 이미지 1개 중 1개
    • Place the basket strainer on top of the tailpiece.
  12. Kitchen Sink Basket Strainer Replacement: 12 단계, 이미지 2개 중 1개 Kitchen Sink Basket Strainer Replacement: 12 단계, 이미지 2개 중 2개
    • Align the upper strainer to the basket under the sink and tighten it with the nut supplied.
    • Use the pliers and turn clockwise to tighten the nut.
  13. Kitchen Sink Basket Strainer Replacement: 13 단계, 이미지 1개 중 1개
    • Tighten the tailpiece nut to the basket.
  14. Kitchen Sink Basket Strainer Replacement: 14 단계, 이미지 1개 중 1개
    • Tighten the trap adaptor nut.
  15. Kitchen Sink Basket Strainer Replacement: 15 단계, 이미지 1개 중 1개
    • Insert the strainer and turn the water back on to test for any leaks.
결승점
작성자
2다른 기여자 명과 함께
Daniel Mella
회원 가입일: 09/15/21
241 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 34
지난 30일: 89
전체 시간: 3,245
