주요 콘텐츠로 건너뛰기
Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly
필요한 것
  1. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly, Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 1 단계, 이미지 1/2 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly, Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 1 단계, 이미지 2/2
    • At the bottom of the kettle pot, remove two 10 mm screws with a Phillips #2 screwdriver.
  2. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 2 단계, 이미지 1/3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 2 단계, 이미지 2/3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 2 단계, 이미지 3/3
    • Open the lid of the kettle
    • Remove two 12 mm screws at the top of the handle with a Phillips #2 screwdriver.
  3. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 3 단계, 이미지 1/2 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 3 단계, 이미지 2/2
    • The exterior of the plastic handle and lid can now be removed from the kettle to expose the electric components.
    • The plastic cover may need a little wiggling to pop off.
  4. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 4 단계, 이미지 1/3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 4 단계, 이미지 2/3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 4 단계, 이미지 3/3
    • Turn the kettle over to the back of the handle.
    • Remove three 10 mm screws connecting the switch circuit to the heating element with a Phillips #2 screwdriver.
    • The heating element should disconnect, allowing you to remove it.
  5. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 5 단계, 이미지 1/2 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 5 단계, 이미지 2/2
    • The pronged power element, removed in Step 4, will have a dry-heating safety feature on the opposite side.
    • This switch turns off the kettle once steam is detected, indicating the water is boiling.
    • This is the boil dry protection switch.
  6. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 6 단계, 이미지 1/2 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 6 단계, 이미지 2/2
    • The inner heating element can now be removed after the completion of Step 4.
  7. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 7 단계, 이미지 1/3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 7 단계, 이미지 2/3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: 7 단계, 이미지 3/3
    • Looking at the bottom of the base, remove two 12 mm screws from the base with a Triangle #2 screwdriver.
    • You are now able to take the black plastic cover off and remove the cord.
결론
첨부 문서
Amanda Yan
회원 가입일: 09/14/22
195 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 43
전체 시간: 452
