소개
The powertrain is comprised of the motor, the gearbox, and the transfer gears. Unlike previous generations of KitchenAid AC Motor bowl-lift mixers, which had these separated into discrete parts, this is a single unit in these models. If any part of this unit breaks, you will likely need to replace the entire unit.
필요한 것
Place a couple dish towels or other soft materials on the base to protect it from any potential impact.
Disconnect the planetary from the motor drive shaft by removing the retaining pin (circled in yellow). You can do this with a hammer and either a pin punch or a Torx T15 screwdriver. Simply hammer the punch/screwdriver on the pin until it comes out the other side.
If the planetary assembly doesn't fall out, you might have to give it a firm pull straight down to remove it.
Using a #2 Philips Screwdriver, remove the screw which holds on the trim band.
Remove the trim band.
Remove the four screws (circled in yellow, two on each side) using a #2 Philips Screwdriver
Remove the cover by lifting it straight up.
Using the T25 Torx Screwdriver, remove the four torx screws by the powertrain (circled in yellow, two on each side)
When removing the last screw, make sure to place your hand under the planetary gear as it is heavy and will fall out immediately.
Remove the hall effect sensor from its mount by pressing down on the tab (circled in yellow in the first picture) and sliding it out.
Disconnect the power cable by holding down the clip on the right side of the plug (circled in blue in the second picture) and pulling the plug straight up.
Using a #2 Philips screwdriver, remove the four screws (indicated in yellow, two on each side) attaching the powertrain to the mixer body.
Remove the powertrain.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
ksm55sxxxcu is the new version i could not replace the motor it has an inner conjuction with the tip.
I could not seperate the motor from the tip. Could you help?
leventercan@gmail.com
Apologies if I misunderstand your question, it is not very clear what you mean by 'inner conjunction' and 'tip'.
The motor is not designed to be taken apart beyond the instructions in this guide. As I state in the beginning of this guide: the motor, the gearbox, and the transfer gears are a single unit.
