주요 콘텐츠로 건너뛰기
KitchenAid Classic Mixer K45SSWH Beater Head Adjustment
필요한 것
  1. KitchenAid Classic Mixer K45SSWH Beater Head Adjustment, Adjust the height: 1 단계, 이미지 2개 중 1개 KitchenAid Classic Mixer K45SSWH Beater Head Adjustment, Adjust the height: 1 단계, 이미지 2개 중 2개
    • Lift the mixer arm and locate the large screw where the base meets the arm.
    • Using a flathead screwdriver, turn the screw counter-clockwise to raise the beater head or turn it clockwise to lower the beater head.
    • The beater head should pass only about 1/16th of an inch above the base of the bowl. One good way to get the height right is to place a dime in the bowl and adjust the height until the beater head barely brushes the dime as it passes.
결론
Once your beater head is at the appropriate height, you're good to go.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Markus Gemperle
회원 가입일: 10/13/14
747 평판
안내서 2개를 작성함
Cal Poly, Team 14-28, Maness Fall 2014 Cal Poly, Team 14-28, Maness Fall 2014 회원
CPSU-MANESS-F14S14G28
4 회원들
안내서 22개를 작성함
3가이드 댓글
Very helpful. Thank you for the info, it worked!!
suz - 답글
I have a K5ss by Hobbart. Do you know how to adjust the bowl/beater clearance.?This machine does not have the screw that adjusts the clearance like the K45ss does. The manual tells how to turn a screw to adjust the clearance on a k45ss, but says to consult an authorized dealer for the k5ss. I called around and nobody in my area works on mixers. Is this something I can do myself? Any help would be appreciated.
Aide L. - 답글
My Beater Head Adjuster Screw hole's threads are damaged, ( I may have crossed threaded the screw) and the replacement screw will not screw in. I need to have the threads chased. None of the local KitchenAid repair locations work on small KitchenAid small appliances, only stoves, friges, ect.
I need someone close 36801 (Opelika Al) and having no luck finding someone.
Any help greatly appreciated
dondford@gmail.com - 답글
댓글 쓰기
조회 통계:
지난 24시간: 26
지난 7일: 216
지난 30일: 377
전체 시간: 16,347
