주요 콘텐츠로 건너뛰기
KitchenAid KHM512ER Beater Rings Replacement
필요한 것
  1. KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: 1 단계, 이미지 2개 중 1개 KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: 1 단계, 이미지 2개 중 2개
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Beater Rings Replacement: 2 단계, 이미지 2개 중 1개 KitchenAid KHM512ER Beater Rings Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
  3. KitchenAid KHM512ER Beater Rings Replacement: 3 단계, 이미지 2개 중 1개 KitchenAid KHM512ER Beater Rings Replacement: 3 단계, 이미지 2개 중 2개
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly.
  4. KitchenAid KHM512ER Beater Rings Replacement: 4 단계, 이미지 2개 중 1개 KitchenAid KHM512ER Beater Rings Replacement: 4 단계, 이미지 2개 중 2개
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
  5. KitchenAid KHM512ER Beater Rings Replacement: 5 단계, 이미지 2개 중 1개 KitchenAid KHM512ER Beater Rings Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Lie the motor down flat on a table.
    • Using a pair of tweezers, remove the ring from the plastic knob.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brad Daniels
회원 가입일: 02/10/16
636 평판
안내서 3개를 작성함
USF Tampa, Team 2-3, Sullivan Spring 2016 USF Tampa, Team 2-3, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G3
3 회원들
안내서 5개를 작성함
3가이드 댓글
Anyone know of a site that sells replacement beater gears?
joescherzo - 답글
Nice set by step process but where does one get the rings?
M Stevens - 답글
try Sears parts.com
Yvette Tower - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 52
전체 시간: 7,577
