주요 콘텐츠로 건너뛰기
KitchenAid KHM512ER Motor Replacement
필요한 것
  1. KitchenAid KHM512ER Motor Replacement, Motor: 1 단계, 이미지 1/2 KitchenAid KHM512ER Motor Replacement, Motor: 1 단계, 이미지 2/2
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Motor Replacement: 2 단계, 이미지 1/2 KitchenAid KHM512ER Motor Replacement: 2 단계, 이미지 2/2
    • Use a Phillips 2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
  3. KitchenAid KHM512ER Motor Replacement: 3 단계, 이미지 1/2 KitchenAid KHM512ER Motor Replacement: 3 단계, 이미지 2/2
    • Using a Phillips 2 screwdriver, remove the three 20mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly and circuit board.
  4. KitchenAid KHM512ER Motor Replacement: 4 단계, 이미지 1/3 KitchenAid KHM512ER Motor Replacement: 4 단계, 이미지 2/3 KitchenAid KHM512ER Motor Replacement: 4 단계, 이미지 3/3
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
결론
다른 2명이 해당 안내서를 완성하였습니다.
[deleted]
회원 가입일: 02/10/16
134 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 26
전체 시간: 4,546
