주요 콘텐츠로 건너뛰기
KitchenAid KSB5CR Circuit Board Replacement
필요한 것
  1. KitchenAid KSB5CR Circuit Board Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 3개 중 1개 KitchenAid KSB5CR Circuit Board Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 3개 중 2개 KitchenAid KSB5CR Circuit Board Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 3개 중 3개
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Circuit Board Replacement, Removing the Back Panel Part 2: 2 단계, 이미지 1개 중 1개
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Circuit Board Replacement, Removing the O-Ring: 3 단계, 이미지 2개 중 1개 KitchenAid KSB5CR Circuit Board Replacement, Removing the O-Ring: 3 단계, 이미지 2개 중 2개
    • Remove the two #6 Hex 82mm screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
  4. KitchenAid KSB5CR Circuit Board Replacement, Removing the Ribbon Cable: 4 단계, 이미지 1개 중 1개
    • Remove the ribbon cable from the chassis by lifting it up.
    • Remove the other end of the ribbon cable from the circuit board by lifting it up.
  5. KitchenAid KSB5CR Circuit Board Replacement, Freeing the Power Cable: 5 단계, 이미지 1개 중 1개
    • Lift up on the power cable to pop it out of its holder.
  6. KitchenAid KSB5CR Circuit Board Replacement, Detaching the White and Black Wires: 6 단계, 이미지 2개 중 1개 KitchenAid KSB5CR Circuit Board Replacement, Detaching the White and Black Wires: 6 단계, 이미지 2개 중 2개
    • Be gentle with the knife or you will break the circuit board.
    • Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
    • Pull the wire out from the metal loop that you loosened.
    • Repeat this process with the black copper wire.
  7. KitchenAid KSB5CR Circuit Board Replacement, Detatching the Green Wire: 7 단계, 이미지 2개 중 1개 KitchenAid KSB5CR Circuit Board Replacement, Detatching the Green Wire: 7 단계, 이미지 2개 중 2개
    • Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
  8. KitchenAid KSB5CR Circuit Board Replacement, Unscrewing the Circuit Board: 8 단계, 이미지 1개 중 1개
    • Remove the #8 Phillips 12mm screws using the Phillips #2 screwdriver.
  9. KitchenAid KSB5CR Circuit Board Replacement, Removing the Circuit Board: 9 단계, 이미지 1개 중 1개
    • Remove the circuit board by lifting it up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Cameron Geehr
회원 가입일: 09/28/14
745 평판
안내서 6개를 작성함
Cal Poly, Team 12-5, Forte Fall 2014 Cal Poly, Team 12-5, Forte Fall 2014 회원
CPSU-FORTE-F14S12G5
5 회원들
안내서 6개를 작성함
3가이드 댓글
Hello, Thanks for video, very good! I see on my blender that main capacitor (blue one) has burned out. Could you tell me the value of it? is it on 110v? many thanks!
Hola, Muy bueno gracias. me voló el capacitor principal (azul grande) me podrías indicar de cuanto es? es para 110v? gracias!
Juan torres - 답글
I have already founded components that burn when plugged to 220v instead 110v. it was a varistor 14D201K, (circular blue), and also burn a thermal fusible besides (black cillinder) . 3A 250V. hope helps someone. thanks.
Juan torres - 답글
Hello, in my case I have lost the motor magnet, additionally the sensor is worn and I cannot see the reference, could you give me the sensor reference, and some idea of ​​how to replace the magnet.
hola, en mi caso he perdido el iman del motor, adicionalmente el sensor esta gastado y no logro ver la referencia, me podrias regalar la referencia del sensor, y alguna ida de como reemplazar el iman.
thank you so much
Miguel Ángel Bareño Bernal - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 33
전체 시간: 2,839
