주요 콘텐츠로 건너뛰기
KitchenAid KSB5CR Motor Replacement
필요한 것
  1. KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 1/3 KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 2/3 KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 3/3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 2: 2 단계, 이미지 1/1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: 3 단계, 이미지 1/3 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: 3 단계, 이미지 2/3 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: 3 단계, 이미지 3/3
    • Remove the two #5 Phillips 95 mm machine screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
    • Remove the ribbon cable from the chassis by lifting it up.
  4. KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: 4 단계, 이미지 1/3 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: 4 단계, 이미지 2/3 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: 4 단계, 이미지 3/3
    • Unhook the white wire that is looped around the peg by pulling it out of the clip.
    • Repeat this process with the red wire on the other side of the chassis.
    • Remove the end cap using the 8" needle nose pliers.
    • Pull up the fan chassis.
  5. KitchenAid KSB5CR Motor Replacement, Removing the Fan: 5 단계, 이미지 1/1
    • Remove the fan by lifting it upwards.
    • This step is difficult and requires force. Use of both hands is recommended.
  6. KitchenAid KSB5CR Motor Replacement, Removing the Metal Cap: 6 단계, 이미지 1/1
    • Use the needle nose pliers to turn the coupling clockwise to loosen it.
  7. KitchenAid KSB5CR Motor Replacement, Removing the Screws: 7 단계, 이미지 1/1
    • Rotate the blender 90 degrees clockwise.
    • Remove the two #8 Phillips 12 mm screws using the Phillips #2 screwdriver.
  8. KitchenAid KSB5CR Motor Replacement, Detatching the Wire: 8 단계, 이미지 1/1
    • Slide the knife in the metal loop holding the insulation before the white copper wire, and wiggle the knife back and forth until it loosens.
    • Pull the wire out from the metal loop that you loosened.
  9. KitchenAid KSB5CR Motor Replacement, Removing the Motor: 9 단계, 이미지 1/1
    • Lift the motor up out of the chassis.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cameron Geehr
회원 가입일: 09/28/14
745 평판
안내서 6개 작성하였습니다
Cal Poly, Team 12-5, Forte Fall 2014 Cal Poly, Team 12-5, Forte Fall 2014 회원
CPSU-FORTE-F14S12G5
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 46
전체 시간: 4,024
