주요 콘텐츠로 건너뛰기
KitchenAid KSB5CR Power Cable Replacement
필요한 것
  1. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 1/3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 2/3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 3/3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 2: 2 단계, 이미지 1/1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Power Cable Replacement, Freeing the Power Cable: 3 단계, 이미지 1/1
    • Lift up on the power cable to pop it out of its holder.
  4. KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: 4 단계, 이미지 1/2 KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: 4 단계, 이미지 2/2
    • Be gentle with the knife or you will break the circuit board.
    • Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
    • Pull the wire out from the metal loop that you loosened.
    • Repeat this process with the black copper wire.
  5. KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: 5 단계, 이미지 1/2 KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: 5 단계, 이미지 2/2
    • Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
결론
Cameron Geehr
회원 가입일: 09/28/14
745 평판
안내서 6개 작성하였습니다
Cal Poly, Team 12-5, Forte Fall 2014 Cal Poly, Team 12-5, Forte Fall 2014 회원
CPSU-FORTE-F14S12G5
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 678
