주요 콘텐츠로 건너뛰기
KitchenAid KSB5CR Ribbon Cable Replacement
필요한 것
  1. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 1/3 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 2/3 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 3/3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 2: 2 단계, 이미지 1/1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the O-Ring: 3 단계, 이미지 1/2 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the O-Ring: 3 단계, 이미지 2/2
    • Remove the two #6 Hex 82mm screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
  4. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Ribbon Cable: 4 단계, 이미지 1/1
    • Remove the ribbon cable from the chassis by lifting it up.
    • Remove the other end of the ribbon cable from the circuit board by lifting it up.
결론
Cameron Geehr
회원 가입일: 09/28/14
745 평판
안내서 6개 작성하였습니다
Cal Poly, Team 12-5, Forte Fall 2014 Cal Poly, Team 12-5, Forte Fall 2014 회원
CPSU-FORTE-F14S12G5
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 468
