소개
Removing the bowl screw cap is easy and doesn't take long. If the bowl doesn't stay in properly you might want to replace this part.
필요한 것
Using a #2 Phillips screwdriver, remove the three 13mm screws holding the bowl screw cap on by rotating them counterclockwise.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
