주요 콘텐츠로 건너뛰기
KitchenAid KSM150PSER Carbon Brushes Replacement
필요한 것
  1. KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: 1 단계, 이미지 1/2 KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: 1 단계, 이미지 2/2
    • Using a flat head screwdriver, unscrew the brush cap on each side of the mixer by turning them counter clockwise.
    • Remove brush cap by pulling it toward you.
    • The brushes are held in by springs and will fly out if removed too fast.
  2. KitchenAid KSM150PSER Carbon Brushes Replacement: 2 단계, 이미지 1/1
    • Remove brush by pulling it toward you.
    • One corner of the brush is flattened. You can check which way the brush is oriented by shining a flashlight inside the hole.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Hayley Young
회원 가입일: 12/03/16
211 평판
안내서 1개 작성함
Cal Poly, Team S2-G5, Livingston Winter 2018 Cal Poly, Team S2-G5, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S2G5
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
I’ve been procrastinating on trying to fix my KA mixer on my own…today I did it. The directions were pretty clear and the only thing wrong was that when I had previously cleaned my mixer, I put the carbon brushes in the wrong way. Once I shined a flashlight into the hole I could see where the notched corner went.
Amber Reimer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 42
30일 전: 200
전체 시간: 14,657
