소개
If your device is not turning on it could be because of worn down carbon brushes. Here is a guide to replace these brushes.
필요한 것
Using a flat head screwdriver, unscrew the brush cap on each side of the mixer by turning them counter clockwise.
Remove brush cap by pulling it toward you.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
I’ve been procrastinating on trying to fix my KA mixer on my own…today I did it. The directions were pretty clear and the only thing wrong was that when I had previously cleaned my mixer, I put the carbon brushes in the wrong way. Once I shined a flashlight into the hole I could see where the notched corner went.
