주요 콘텐츠로 건너뛰기
KitchenAid KSM150PSER Circuit Board Replacement
필요한 것
  1. KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: 1 단계, 이미지 1/2 KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: 1 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling it back and up.
    • Ensure that the mixer is disconnected from any electrical source prior to removing the back cover.
  2. KitchenAid KSM150PSER Circuit Board Replacement: 2 단계, 이미지 1/2 KitchenAid KSM150PSER Circuit Board Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the 9.5mm screw above the circuit board by rotating it counterclockwise.
    • If you can't see the screw, try pulling the seal down past the wires to make the screw more accessible.
  3. KitchenAid KSM150PSER Circuit Board Replacement: 3 단계, 이미지 1/2 KitchenAid KSM150PSER Circuit Board Replacement: 3 단계, 이미지 2/2
    • Using pliers or tweezers, remove the connectors of the four wires attached to the circuit board.
  4. KitchenAid KSM150PSER Circuit Board Replacement: 4 단계, 이미지 1/1
    • Grab the wires and tilt the edge of the board up to lift the circuit board up and out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Luke Leonard
회원 가입일: 01/24/18
562 평판
안내서 2개 작성하였습니다
Cal Poly, Team S2-G5, Livingston Winter 2018 Cal Poly, Team S2-G5, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S2G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 35
전체 시간: 5,211
