주요 콘텐츠로 건너뛰기
KitchenAid KSM150PSER Power Cord Replacement
필요한 것
  1. KitchenAid KSM150PSER Power Cord Replacement, Power Cord: 1 단계, 이미지 1/2 KitchenAid KSM150PSER Power Cord Replacement, Power Cord: 1 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling back and up on the cover.
  2. KitchenAid KSM150PSER Power Cord Replacement: 2 단계, 이미지 1/2 KitchenAid KSM150PSER Power Cord Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
    • Pull the trimband off the housing by grabbing each side and pulling it off the front.
  3. KitchenAid KSM150PSER Power Cord Replacement: 3 단계, 이미지 1/2 KitchenAid KSM150PSER Power Cord Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using a Phillips #2 screwdriver, remove the 12mm screw holding the grounding wire in place by rotating it counterclockwise.
    • Using pliers or tweezers, remove the connectors attached to the white and black wires.
  4. KitchenAid KSM150PSER Power Cord Replacement: 4 단계, 이미지 1/2 KitchenAid KSM150PSER Power Cord Replacement: 4 단계, 이미지 2/2
    • Using a screwdriver, pull the cord string relief out of the mixer by putting it behind the cord and pulling away from the mixer until it is free.
    • Remove the cord from the mixer body.
결론
Max Prohorov
회원 가입일: 01/24/18
109 평판
안내서 1개 작성함
Cal Poly, Team S2-G5, Livingston Winter 2018 Cal Poly, Team S2-G5, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S2G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 46
전체 시간: 4,116
