주요 콘텐츠로 건너뛰기
KitchenAid KUDS01DJSS0 Electronic Control Board Replacement
필요한 것
  1. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement, Electronic Control Board: 1 단계, 이미지 1/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement, Electronic Control Board: 1 단계, 이미지 2/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement, Electronic Control Board: 1 단계, 이미지 3/3
    • Unplug the dishwasher or shut off the house circuit breaker for the dishwasher.
    • To verify that power is disconnected, make sure that the control panel doesn’t light up when you press a control button or the power button.
  2. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 2 단계, 이미지 1/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 2 단계, 이미지 2/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 2 단계, 이미지 3/3
    • Open the dishwasher door.
  3. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 3 단계, 이미지 1/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 3 단계, 이미지 2/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 3 단계, 이미지 3/3
    • Remove the four screws from each side of the dishwasher door (eight screws total).
    • Removing the three screws from each side of the dishwasher (six screws total).
    • Support the outer door panel with one hand as you remove the final two screws at the top of the dishwasher door.
    • There are total of sixteen (16) screws.
  4. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 4 단계, 이미지 1/2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 4 단계, 이미지 2/2
    • Use your hands to pull off the outer door panel with the control panel.
  5. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 5 단계, 이미지 1/2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 5 단계, 이미지 2/2
    • Disconnect the two white outer wires by pulling them out.
    • The two white connectors have the same size and are close together.
    • Use one hand to hold the control panel while disconnecting the electrical connections from the old board.
  6. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 6 단계, 이미지 1/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 6 단계, 이미지 2/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 6 단계, 이미지 3/3
    • Remove the white rectangular connector that has six colored wires connected to it.
  7. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 7 단계, 이미지 1/2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 7 단계, 이미지 2/2
    • Use one hand to hold the control panel while detaching the black connector.
    • The black connector is the main connector to the control board.
  8. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 8 단계, 이미지 1/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 8 단계, 이미지 2/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 8 단계, 이미지 3/3
    • Detach the white and gray ribbon cable attached to the black connector.
  9. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 9 단계, 이미지 1/2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 9 단계, 이미지 2/2
    • Use your hands to pull the electronic control board out the mounting slots.
  10. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 10 단계, 이미지 1/2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 10 단계, 이미지 2/2
    • Push the new electronic control board into the mounting slots.
    • Slide it to the right to engage the locking tab until you hear a click.
  11. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 11 단계, 이미지 1/2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 11 단계, 이미지 2/2
    • Reconnect the black connector wires to the new electronic control board.
  12. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 12 단계, 이미지 1/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 12 단계, 이미지 2/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 12 단계, 이미지 3/3
    • Reconnect the white rectangular connector with six wires to the new electronic control board.
  13. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 13 단계, 이미지 1/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 13 단계, 이미지 2/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 13 단계, 이미지 3/3
    • Reconnect the two white outer connector wires to the new electronic control board.
  14. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 14 단계, 이미지 1/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 14 단계, 이미지 2/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 14 단계, 이미지 3/3
    • Reinstall the outer door panel and control panel on the inner door panel and reattach the user interface control wire harness.
    • Reinstall the sixteen mounting screws.
  15. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 15 단계, 이미지 1/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 15 단계, 이미지 2/3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: 15 단계, 이미지 3/3
    • Connect the dishwasher and reset the circuit breaker for your house to restore electricity.
    • To verify that power is connected, make sure that the control panel does light up when you press a control button or the power button.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Thuan Trang
회원 가입일: 01/13/22
345 평판
안내서 1개 작성함
York University, Team S-29, Woodhouse Winter 2022 York University, Team S-29, Woodhouse Winter 2022 회원
YORK-WOODHOUSE-W22SSG29
1 회원
안내서 2개 작성하였습니다
댓글 4개
Excellent illustration!!!
KO SAMUEL TAK SHUN - 답글
عمل فنى رائع وجميل وبدقة متناهية
khaliddabnoun - 답글
عمل فنى جميل ورائع وبدقة متناهية
khaliddabnoun - 답글
Excellent how to! However the part attached to purchase doesn’t look like the original control board. Help!
magdelena kormusis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 42
전체 시간: 1,340
