필요한 것
Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
Remove the silver band.
Remove the 4 Phillips #2 screws connecting the black housing cover to the device.
To remove the Bevel Gear, remove the snap ring wrapped around the base of the gear using Snap Ring pliers.
Slide the Bevel Gear off.
Before replacing part, make sure you remove all the old grease (the black gunk). It could contain metal shards that will quickly wear down gears. I used a 50% alcohol and a lot of rags and cotton swabs (Q-Tips®). Make sure everything is dry before placing new food-grade grease.
mommarosie - 답글
I removed the snap ring but my bevel gear is locked and I cannot remove it. I suspect the pin located below it is broken. Any suggestion? What can I do to replace both bevel and worm gears?
My bevel gear (serviced once by the local KA authorized service center) appears to be secured by some means other than a snap ring. There are no holes or breaks, it appears solid all the way around. Any ideas?
다른 9명이 해당 안내서를 완성하였습니다.
댓글 14개
I was thinking , - my god what a excelent tec. contribution material before watched your naked hands whit a lot of greasy spots
I’m from Ensenada Baja California “mother land of the internatiomal score baja off-road races“ and here we have a Doctor Simi drugstore’s where you can buy a pair of natural latex gloves whit or whitout powder s - m - l for less than one u.s. dollar. I buy gloves in monday’s because i pay 10 mexican pesos for it. “The little details son los que la cagan “
Need to know if after removing this bevel gear, does that allow the gear below it to be removed also? Because this is the one I need to replace.
Thanks
Once the Bevel Gear is removed you will see a pin that can be pushed out with a punch or small screw driver. That allows to you to remove the Worm Follower Gear. Keep you hand under the machine as the whole shaft can slide down. It’s pretty straight forward.
Same issue - did you solve it?
I have same problem as scoretti@gmail.com. Cannot lift off bevel gear after removing snap ring. Help!
Same issue - how did you solve it?
Same here! Any suggestions?
Same issue - did you find a solution?
If the bevel gear will not slide up unrestricted, you’ll need to get a pair of locking pliers or channel locks. Then, while holding the paddle attachment in place with one hand, wiggle the gear to move it up the shaft incrementally. It could take a bit depending on the age of the unit but I literally just went through this before coming across this post.
My bevel gear got stuck won't come off, and I cannot seem to fix the issue if I cannot get the bevel gear off first.
Maybe start with unplugging it ?
Ryan F - 답글
