주요 콘텐츠로 건너뛰기
KitchenAid Professional 600 Drive Motor Replacement
필요한 것
  1. KitchenAid Professional 600 Drive Motor Replacement, Top Cover: 1 단계, 이미지 1/1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
  2. KitchenAid Professional 600 Drive Motor Replacement: 2 단계, 이미지 1/1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Drive Motor Replacement: 3 단계, 이미지 1/1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Drive Motor Replacement, Speed Selector: 4 단계, 이미지 1/1
    • Locate the selector switch.
    • Remove the two Phillips #2 screws holding the selector switch in place.
  5. KitchenAid Professional 600 Drive Motor Replacement: 5 단계, 이미지 1/3 KitchenAid Professional 600 Drive Motor Replacement: 5 단계, 이미지 2/3 KitchenAid Professional 600 Drive Motor Replacement: 5 단계, 이미지 3/3
    • Unplug the cords attached the drive motor to the switch.
    • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
  6. KitchenAid Professional 600 Drive Motor Replacement: 6 단계, 이미지 1/1
    • Pull out the Selector Switch.
  7. KitchenAid Professional 600 Drive Motor Replacement, Drive Motor: 7 단계, 이미지 1/1
    • Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
    • The picture only shows one of the screws. The other screw is located on the exact opposite side of the motor.
  8. KitchenAid Professional 600 Drive Motor Replacement: 8 단계, 이미지 1/1
    • Pull upward to remove the motor.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tallon Dotinga
회원 가입일: 04/11/16
487 평판
안내서 2개 작성하였습니다
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016 회원
CPSU-MANESS-S16S25G4
4 회원들
안내서 18개 작성하였습니다
댓글 4개
anyone know where I can get the hall effect sensor receiver that is on the motor shaft? Somehow it's missing?
Barclay Berger - 답글
is there not a fusible link in series with the drive motor?
wa1shm - 답글
I accidentally pluged my 110v mixer to 220v. Now, what are the possible parts that i need to change? How can i check if the motor is busted?
hyalmar planta - 답글
Are the motor brushes serviceable on this model mixer and where are they located
Thanks
Gary Bell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 43
30일 전: 184
전체 시간: 12,161
