주요 콘텐츠로 건너뛰기
KitchenAid Professional 600 Gear Housing Cover Replacement
필요한 것
  1. KitchenAid Professional 600 Gear Housing Cover Replacement, Top Cover: 1 단계, 이미지 1/1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
  2. KitchenAid Professional 600 Gear Housing Cover Replacement: 2 단계, 이미지 1/1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Gear Housing Cover Replacement: 3 단계, 이미지 1/1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Gear Housing Cover Replacement, Gear Housing Cover: 4 단계, 이미지 1/1
    • Remove the 4 Phillips #2 screws connecting the black housing cover to the device.
    • Only one of the screws is seen in the picture. The other three are also located around the black housing cover.
  5. KitchenAid Professional 600 Gear Housing Cover Replacement: 5 단계, 이미지 1/1
    • Take off the black housing cover.
결론
Luke
회원 가입일: 04/11/16
1,353 평판
안내서 5개 작성하였습니다
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016 회원
CPSU-MANESS-S16S25G4
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
I find your instructions very helpful but one of my housing pins have broken off, Can it be replaced or do I need to replace the housing? If so where do I find the housing part. I can not find it.
w.gupton - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 34
전체 시간: 2,825
