소개
This guide will provide a detailed step-by-step instruction guide on how to remove the power cord from the KitchenAid Professional 600.
필요한 것
Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
Remove the silver band.
Locate the selector switch.
Remove the two Phillips #2 screws holding the selector switch in place.
Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
Remove the Phillips #2 screw attaching the green grounding wire to the frame of the mixer.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Any idea where I can buy the power cord itself?
