주요 콘텐츠로 건너뛰기
KitchenAid Professional 600 Top Cover Replacement
필요한 것
  1. KitchenAid Professional 600 Top Cover Replacement, Top Cover: 1 단계, 이미지 1/1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
  2. KitchenAid Professional 600 Top Cover Replacement: 2 단계, 이미지 1/1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Top Cover Replacement: 3 단계, 이미지 1/1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Luke
회원 가입일: 04/11/16
1,353 평판
안내서 5개 작성하였습니다
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016 회원
CPSU-MANESS-S16S25G4
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 46
전체 시간: 2,498
